Probabley With My 90 Accord
    whats up guys im rick i have a 1990 accord that runs but when i stop the car dies i just replaced the spark plug wires and it runs smoother but it still dies any ideas of what it is
    did you replace the plugs too??? What about the cap and rotor? If those are done, i might look into the dizzy...
      X2 on that..
      check into changing out your Dizzy and...I might add...
      changing out the ignition switch ( inside column cover...left side of keylock assembly )
      15 minutes TOPS!
      but yeah...change out the dizzy with a NEW one...if you have the greenbacks..get it from HONDA..and upgrade your plugwires..to NGK blues!
      and keep the ones you have as spares!
      plugs: NGK or DENSO
      92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
      MR Thread:
        probabley just get urself some wire brush and jus clean yur battery connections cuz they probabley be the probabley. that or check ur grounds to make shure they aint broke. if that doesn't work, then do what the guys above said.
          eye cee wut u did thur.
            maybe bad alternator?
            1991 Lx coupe........traded now I have nothing lol
              COuld be it
              The distruter on those cars go alot and they are sometimes the hardest to find. My buddie I-07 had the same thing it would go good butthen would die if you would stop. Its the whole thing not just the cap and it not that hard to replace but i just changed one this moring with my friend so if that any help to you i hope you can get it fix man.
