EK not braking
    EK not braking
    alright i just got done doing a rear disk brake conversion on my friend's 96 civic hatchback dx...we used the disks brakes from an integra...everything is installed with new pads for the rear and front rotors, new front rotors...the ebrake cable has not been install yet since my friend had to order a civic SI ebrake cable cuz the ebrake cable that came with the istalled integra rear disk brakes are too short...the entire brake system has been bled about 3 times already and there is fuild in the system, but the problem is that the brake pedal still goes all the way to the floor and the car brakes very poorly...the car is stopping like it has no brakes at all...I Need Serious Help...thanks
    A wise man sees failure as progress...
    Did the master cyc go empty during your swap? if so then you have more bleeding to do.
    WHY ARE HURRICANES NAMED AFTER WOMEN? CUZ WHEN THEY CUM , THEY ARE WET AND WILD AND WHEN THEY LEAVE... THEY TAKE YOUR HOUSE, YOUR CAR AND YOUR MONEY....!
      You might wanna recheck the system for possible leak somewhere.
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        Bump
          id say it needs to be bled some more...3 times isnt enough....
            If the pedal is going to the floor, the system doesn't have the proper pressure. Definitely bleed it some more. Is the master cylinder new?
              how are you bleeding it? is the MC any good? advanced auto parts has those convinient one man speed bleeders.you only bleed once all the way around. Gets all the air/bubbbles out. saves major headaches.
                man nothing worked...we bought the one man bleeder...we even bought the brake bleeder system which costed over $100...a new brake booster....a new master cylinder....nothing worked at all...the brake pedal still goes all the way to the floor... the are no leaks, the fuild levels are still full...so im scratching my head on what could be the problem....
                  You always bleed the brakes starting from the furthest away from the Master Cylinder. Theres a pattern you need to follow for fwd vehicles.
                    well for one are u puttin the bleeder valve on the caliper on before you put the brake fluid in. that can keep air pockets in ur brake system. Also there is a allen key bleeder valve under the master cylinder, make sure its not leaking from there. if its falling to the floor, u have an air bubble somewhere or a leak somewhere. check the MC and see if it stays full
                    1990 Accord EX Sold
                    1995 Accord LX V6 Stored
                    1999 Accord LX Daily Driver
                      make sure u bleed from the caliper also because it can be a bubble there
                      1990 Accord EX Sold
