head specs
    head specs
    Ok, i want to take my head off and give it to a company to have them polish and port it. I also have herd that shaving the head down will help with power as well, I do in the fueture want to Turbo the car and i would kinda like to know what i should have done to it to get power now and still have it and it work well when it is T'ed. I have a stock H23a with a Apexi SAFC2 controller...thanks
    a Honda that eats mustang GT's for breakfast, wow
    Ok im assuming you mean "mil" the head?
    If you search there should be a few threads that cover this.
      i guess i am new to this and would like a bit of a teaching,
        bump, can someone help me please?
          milling the head will give a higher compression. I believe forced induction doesn't like a higher compression, especially when boostin. I would suggest get only a port and polish.
            get the P&P and have them make trim the head to make sure its a perfectly straight, also if you can have the same done to the block.
            Click Me
              Depends on how much you take off...And higher compression with turbo motors make pretty good power. IT depends on the tune mainly for higher compression. With E85 now its easier to work with. Anyways you wont be goin that much higher depending on how much you mill the head. H23A1 stock is like 9:1 compression or something like that. Its not that bad.
                Turbo likes high compression. High compression just leaves less room for error.
                I've been told by a knowledgeable guy that porting the head can weaken it, and that just a polish will do well. I have nothing to back this up, other than the fact that this guy knows a good deal (he's Accord SiR's friend). Might be something to ask.
                Honestly, ask the shop. If it's what they do, they should be able to give you some guidance on what would be best. If they don't know enough to guide you, perhaps they don't know enough to do a good job on your head!
                  WEll, the NAPA over here has a region shop in like alpharetta and they do manchine work like p&P and i have herd great things from other guys about their work. Now i was just hoping that i didnt have to ask them, becuase most likely they wont know anything about Turbo's and they wont be as much help as you guys (most peps in GA at turbo retarded) as far as shops go...... like so i should only polish the head and should i do anything with the intake mani?
