Originally posted by ex_style90
92 Accord LX, No compression.
Originally posted by ex_style90Umm lets see
f20b dohc vtec - $950
h22a vtec - $790
and oh forgot
f22b dohc - $550 These are all from tigerjapanese.com GL
If there is a hole in your piston there is a problem too...That will cause a no compression and worst of all smell your oil for traces of gasoline. The only way your dad can see the chamber without taking off the head is taking out the plugs with a small light and lookin around. then you still dont see much. You can see most but not all of it.
Originally posted by NAiL05If there is a hole in your piston there is a problem too...That will cause a no compression and worst of all smell your oil for traces of gasoline. The only way your dad can see the chamber without taking off the head is taking out the plugs with a small light and lookin around. then you still dont see much. You can see most but not all of it.
Yea, That is what he did and he said there was a hole in it. Yea, I think I'm just going to buy a new engine. I'm looking at a H22 Automatic. Is that a good engine?
This thread is all over the damn place.
To check your rings, you will have to take out your engine(this is the easiest, but longest way) Take off the head, take off everything from underneath the engine and pretty much tear down the whole block. It's more work than its really worth.
Try and take off the timing belt by pulling on it hard or try to slip it off. It should take a lot of force to slip it off. If it goes off, then it broke.
Do you get spark?
