transmission ??????????
    my trani is messed up the sports light blinks and i have to take of on first i was wondering should i get a used one or rebuilt mine also i heard when u change the transmission or engine is doesnt run as well as it used to can anyone help
    http://www.cb7tuner.com/vbb/showthre...t=sports+light
    No need to replace your tranny.
    Just search this forum and you shall find your answer without having to create a thread.
    From that thread it sounds like it could be your TCU...a fried resistor...pull it, open it up, and look a fried resistor..if you find one replace.
    It might also be a solenoid.
    Look around for the thread on pulling your codes....
    post what codes its throwing(if any) and that can help us to help you.
    And ive never heard of replaced trannys not acting as well as stock.
    As long as the swap is done correctly and the tranny is servicable cond and you have the right TCU it should work just fine.
