ok guy so i had my ac workin ice cold for about a week then today im driving cranbk it on and wen im at a light just hot air comes out but wen im driving its starts to cool down alot so i checked the the recircilation button to see if i had it for ram air instead of the fan buit no that was fine so i have no idea wats wrong wat do u guys think?
a/cproblem
could be the condensor. mines used to do that and I installed the condensor, and cleaned it with compressed air, degreaser and a hose. If its dirty or clogged air won't flow/cool it properly.89 Acura Integra 1.6 LSt (Daddy's Boost Toy)
94 Honda Accord 2.2 EX (Daily For Now)
04 Chevy Suburban 5.3 LT (Kiddie Haulin Pimpness)
To a degree, that issue is also normal... It shouldnt die at a stand still, but it will blow less...
Disregard females, acquire currency.
My 2003 Nissan Maxima Members Ride Thread
DIY: HOW TO POST PIC(S)
Check your a/c clutch fuse on the kickpanel. I recently changed my condensor since that was the reason i had a leak in the system it was all working good. Then 2days i turn on my a/c and nothing but hot air...next day i ended up checking the fuses long and behold it was a blown a/c clutch fuse...Just curious is there a way to check those relays on the side fender next to the drier?
My Cb bad, Cb bright and the cops can kiss my Cb lights - I’m gone!
Frost White Member 13
My Ride
"Girls are like a new car... lease w/ option to buy"
Originally posted by icedplaya123Check your a/c clutch fuse on the kickpanel. I recently changed my condensor since that was the reason i had a leak in the system it was all working good. Then 2days i turn on my a/c and nothing but hot air...next day i ended up checking the fuses long and behold it was a blown a/c clutch fuse...Just curious is there a way to check those relays on the side fender next to the drier?89 Acura Integra 1.6 LSt (Daddy's Boost Toy)
