thats right the s2000 i forgot about that. anyway. im off to do some research and junk yard hunting.
v6 in 4th gen?
1) You are all over the map. One second it is a C27, and the next it is a J32. Lack of focus will make a project like this far more expensive, and far more difficult. Maybe even impossible.
2) Please, please, please read the thread posted above. Most of what you are going to need to know is already covered in that thread.
I will summarize:
A) The J series is more common than the C series. Why? Because it has powered every V6 Honda vehicle with the exception of the RL and NSX since 1999. Millions have been built.
B) The Jseries is SMALLER AND LIGHTER than the C series. They have a more compact V angle, a smaller valve train, the same all aluminum construction, and a generally more compact design.
A J series with manifolds on it is smaller than an F22 with manifolds on it. It only weighs slightly more.
C) Not all C series V6's are the same. The first gen Legend and the C27 from the Accord are substantially different than the C32 in the Legend. The NSX is pretty much its own engine.
The reason this is important, is that the 3.2 in the 2nd gen Legend was mounted longitudinally, like a rear drive car. THe transmission hung off the engine like a RWD car, and the drive shafts sprouted out the sides, as opposed to out the end where it would have driven the rear wheels easily.
This will make it pretty much impossible to use the 2nd gen Legend tranny and engine.
D) The C series Accord V6 probably had different frame rail brackets, just like the 6th and 7th gen Accords do. So most likely you are going to have to fabricate these anyway.
E) The C27 will not provide a large increase in acceleration over an F22 with bolt ons, if any.
F) The J series already has a FWD 6 speed manual tranny that fits all of the J series engines. It is also more common than the Legend manual trannies, and is available with LSD.
Coming from a man that has researched it
The only downside to the J series is the initial cost (though you will get a better motor, in most cases) The C27 would be very cheap, since it's such an old engine.
However, you are absolutely right about it being a minimal upgrade. It's only .5L bigger in terms of displacement. It's heavier, and the aftermarket support is most likely more limited than the F22 aftermarket. The ONLY reason for doing it with a C27 would be just to have a V6 in a CB7. If you had the tools, supplies, abilities, and facilities to do all the fabrication yourself, the C27 swap would be reasonably inexpensive.
Off Topic:
I wonder if the s2000 transmission could somehow be mounted to the C32 in the 2nd gen Legend... then have a modified driveshaft running back to the S2k differential, running custom axles. Think the Legend could be made RWD relatively easily?(I know it's probably VERY involved... and for all I know, the motor turns the wrong way... since I know nothing about the Legend)
Off Topic:
You are starting with AT LEAST a 30HP advantage, and around 30 lb/ft of torque too.
Plus, in the 5th gen, the V6 was only a couple 10ths faster than the 4 cylinder. It did have some extra features, but it would most certainly lose to an H22.
For the amount of effort involved, my opinion is that it wouldn't be worth it unless the performance potential is there.
Just saying I have a V6 to me isn't worth it when the H22 can offer so much more right out of the box.
With a 286HP J35 that puts out about 256WHP, and 235 WTQ with an LSD, the potential is there. With 170CHP and ~ 170CTQ it really isn't. At least not as much.
Then it is fairly easy to get an additional 30-40 WHP out of a J series with good flowing bolt ons, and EMS. So you could be looking at somewhere between 280-300 WHP without ever cracking a valve cover open.
Obviously, there are other J series options that would be more affordable, and you can pretty much mix and match to make any J similar to any other J, but at least the potential is there.
Plus, the lighterweight makes them weigh almost exactly the same as an H22, so you could get it without having a hugely nose heavy car.
The other advantage is servicability. The J has longer maintenance intervals, and is easier to work on when it needs them. The old C series still had a lot of add on components like the CB7 does, and the valvetrain would be a bitch to get to, with the way the V angle is 90 degrees (as opposed to 60) and the complex layout of the valvetrain.
I believe the C series would be slightly wider than an F22 with manifolds on, because the J series is smaller than the C, and it is JUST BARELY smaller than the F with manifolds on it.
Also, apparently, in regards to your Legend question... The take off yoke for a rear driveshaft is already inside the tranny apparently. You would need to modify the end housing, and then fabricate it all up.
I was also told that the rear subframe was pretty much designed to support a rear diff, so it would appear that Honda either had plans to make the Legend AWD, or they at least wanted the capability to do so.
Honestly, based on a good Acura source I have, he said it wouldn't have been at all difficult to achieve AWD.
And Honda was playing around with AWD at that time.
THAT would be a fun car.
Also, here is a good idea for someone. Get the J35 with SH-AWD in a CB7 and see what happens.
That would be a mean CB7.
Spoon/Opak Racing has a current gen RL, that they road race. After they stripped it down and took all the luxury out, it weighs about 2900lbs, and with the bolt ons is putting out about 330HP. The engine has like an exhaust and intake.
Think about a similar weight CB7, and you get the idea.
Plus with SH-AWD, there are no real "chassis limits" like there would be with FWD, AND you really are only limited by the SH-AWD powertrains ability to absorb power.
TT 500 HP is just some modification away. LOL!
Some of which would be modifying the chassis for sure, but still.
One selling point in the future for the 7th gen Accord and the TL, is that apparently it bolts into those chassis with little diffculty. Those are the cars Honda tested it on.
Don't know how true that is, but the rumor mill has suggested it, so it is certainly something to consider, and with the similarity of the cars on that platform, it would make sense.
ok check it were way off track here guys. alot of really good info coming in but lets get back to the matter at hand. so far im looking at the options of a c27 and a j30 from what i can understand you guys agree that a j30 would be the best way to go for power and everyday use. but for cheaper a c series. im gonna do some more price research and ill get back to you.Hey yo uhhhhhh fry man!!!!
Originally posted by owequititAlso, here is a good idea for someone. Get the J35 with SH-AWD in a CB7 and see what happens.
TT 500 HP is just some modification away. LOL!:
