wheel studs
    wheel studs
    i twisted off 2 the other day cause sum1 cross thread the lugs so im driving around with only two lugs holding on my left front wheel. i tried getting the bad one out but they wouldnt clear the hub so im stuck wit that... any help on how to get them out and put new ones in???
    bump
      Take the hub apart punch out the old put in the new then put the hub together and reinstall.
        im gonna have to take this to a machine shop right?
          i'm in a similar situation bro. basically if you don't have the tools or your friends don't have access to tools you need to take it to a shop.
          hey. my cb7 has morphed. haha.
            don't drive with only two studs! not safe!
              maybe I can help. I know that there are more guys out there with the similar problem. use a hammer and bang the shit out of the studs to get them out of the hub. then with the new stud, use a grinder and grind off alot of parts off of the end (not where there are threads, the other end.) enough to where it can clear the knuckle, and then use an impact to drive a nut or something to pull in the stud. I hope that I am clear enough ( I don't think I was) good luck and ask any questions if have any.
                This does NOT work if the hub lip is in the way...The only way this will work is if ther ewas a notch in the back where you knock out the studs to replace...Some cars have this and makes ease of install and removal easier...Another thing no grinding down studs...Its just a bolt side then a thread...Your asking for trouble. IF you have hub lip in the way you have no choice but to press the hub and crap to get to it then reinstall (unless y ou decided to grind part of it off which also is not a good idea). Pretty nice to have some nice tools around to do. you dont have to use an impact driver to pull it through if you dont have air tools you can do it with a ratchet by hand. It just takes longer but it works.
                  guys i had no choice the car is my daily driver so i was even racing it on the freeway with only two studs (dumbass). thanks for your input guys but how much do you think ist gonna cost to press the hub and fit the new studs in and how long will this take the average mechanic?
                      works for REAR but not front
                        haven't tried it on a accord yet but on civics it does. just a suggestion though. anyhow, it will cost a good amount of money. how much?? it varies on who you take it to.
                          We did buddies Teg. He already had the knuckled pulled. And took us 10 min to install and reinstall if not even that.
                            search and you shall find..
                            http://www.cb7tuner.com/vbb/showthre...highlight=stud
                            http://spyfunkr.com/accord/studrepl.htm
