I don't know where I got 145 from...
Even the mild Red build is fairly involved for the average tuner, but it certainly shows what gains can be had from moderate work, while retaining full streetability. I would also think that a Bisimoto header would be a bit of an improvement over that Kamikaze... though an ECU retune might be in order to fully realize it.
Still, 152whp on a Mustang dyno (as owequitit said previously, those dynos generally read lower than most, like the Dynojet) is quite impressive. An H22 generally only makes about 10whp more in good condition. At 26-29mpg, this fairly mild F22 build puts it damn near the H22 range!
Cisco, you should total up the cost of all your parts... or at least what they would normally cost, if you got yourself any sort of deal on them. I'm curious to see how much you spent!
And yes, a properly maintained and healthy F22A bottom end can rev well beyond the stock limits... but I'd still be afraid to do it on a regular basis. Without at least new OEM parts in the block, I wouldn't risk revving past the stock redline... especially if I had expensive headwork done! Not saying it WILL fail, but that it COULD fail (as could brand new, high quality components, actually...)
