Brake lights
    Brake lights
    about a year ago i had to change my combination switch because my taillights was not working but my brake lights worked, now my taillights still work and my brake lights no longer work. Is it the combination switch again or do anyone know what can it be?
    honda life 4218
    Is your bulbs fine, fuse blown, maybe some wiring in the tails messed up?
    My Official Vouch Thread
    MY For Sale Thread!!!
    Recent Members Sold To:
    ALOW1, TheNextAZN
    Members Sold To (Vouches):
    ALOW1, Phempa, hpaccord91, aznsyco84, 93EXaesthetic, civic_90_08, wrichards2005, SuperTuner12010, JDM_EJ, Ralphie, cooneyb81, HondaFan81, quakerjoe, tanNn2koo, 91Accord-LX, JARHEAD293, TheNextAZN, (TONS MORE)
      you should check your brake sensors on the tails for corroded or fried up harness. I would also do what xwade01 said.
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        yea i checked the fuse and it is good. i know it's not a bulb because they all went out at 1 time including the third brake light. i can check for corrosion but where?
        honda life 4218
          on your left or right taillights. Pop yo trunk then check your harness and plugs for corrosion. I have the same crap as you then it turned out to be that my taillight harness was fried. If the harness are good and have no bad signs of whatsoever it would be your brake light sensors on the taillights.
            is there a main harness?
            honda life 4218
              just check the harness on the tails. The culprit might be there.
                ok i'll let u know the info
                honda life 4218
                  make sure you chekc for rust , corrosion and melted sh!+
                    i checked for all of the above and my wires look like i just got the car brand new. Could it be the Brake Switch where the foot pedal is?
                    honda life 4218
                      does anyone know how to tell if u need a new brake switch?
                      honda life 4218
                        Shiet , I forgot to tell you about that. That might be the answer to it.
                          believe it or not it has been a few months and also since I gave up for a while I finally fixed the problem with my brake lights. it was so simple yet stupid. well it all started after changing my ignition switch, I had to remove my steering wheel which caused my srs light to come on which took away my horn and cruise control. well some how I don't know how but our brake lights are in someway connected with the horn. when I was diagnosing my car I never checked the horn fuse because I didn't have a horn anyway but that fuse it the reason I had no brake lights. it was that simple.
                          honda life 4218
