electrial issues?
    electrial issues?
    so, i went out and tryed to start my car the other day and it wouldnt start. it would click when i turned the key and thats it. i checked the battery, and alt, and cleaned and checked all my grounds. fuses were good as well. i know its not the starter because it will jump start. does any one know whats going on?
    thanks
    Take a DVOM to the battery to double check. What voltage were you getting? or did you take it to a parts store to check. When it cranked up did you leave it running since you had it sitting for a while to charge the battery?
      i took it to schucks to get it checked, im not sure what a DVOM is so i dont know if i have one, and yes i left it running for about 20 mins just to make sure.
        So basically they put a load test on it and said it was ok huh? Hmm any dimming of the headlights or anything when your running? DVOM is basically just a volt-ohm meter. Normally a volt meter would just suffice as long as it reads DC current. It wouldnt start back up when you turned it off?
          not while it was running, however my stereo kept cutting out while i was driving.
            Hey
            Same deal on mine. It can be jumped, but will just click when tried on its own. If you put on the brakes it will shutoff the radio momentarily and dim the lights. I thought it was the starter (havent replaced it yet) but could be electrical. I did replace both neg and pos cables, im gonna check the fuse box again, fuses looked good, but maybe its the wiring. Anyone HELP!
              Originally posted by niemo435
              Hey
              ahh yes time to resolve this!!! .. it's happening to me as well.
              Originally posted by wed3k
              i rep cb7tuner all day, everyday. people say, "fuck y0 honda." and i say, "bitch, please."
                If you know you have good batt voltage and when you start starter decides not to work....thats your starter. You can try the screwdriver by jumping the two leads that will let you know it is the starter. If you can tap it and it starts it is the starter. The solenoid inside is no good or the points where it makes contact is wore out. Which can cause no start or take long as hell to start or in most cases just a click.
