where can i get all my motor mount in steal? i ahve seen for hatchback swaps but it wouldnt be fair if w can get them for our cars.
steal motor mounts
If you meant steel than the mounts you're talking about aren't actually solid steel all the way through. Mounts like the ones from hasport are a steel shell but filled with polyurethane.Last edited by Chrisisiced; 06-11-2007, 05:20 PM.
There are different types of Urethane as well... Filling the stock mounts is a common practice, and fairly easy (and cheap) to do. It accomplishes the same results on a car that doesn't NEED extra-strong mounts. Honestly, unless you do something wrong, it's VERY hard to break a stock mount with the rubber intact.
With a softer urethane, you can minimize some of the vibrations caused by the filling of the mounts. Of course, you're also going to have more flex, so the performance won't be the same as the stiffer urethane either. As with most aspects of modifying your car, you sacrifice some comfort for more performance.
