auto tranny problem
    auto tranny problem
    okay well this is the second tranny i've had from hmotors and well we installed it and it seems to have the same problem as the last one did... "airration" or however it's pronounced, well it is just basically something inside the tranny is leaking and my car doesnt shift past 4k rpms unless i use manually d1, d2, d3 ,d4 is this bad for the car? or is there something f'ed up with the tranny again? it seems to be making this "grrrerrgrr" sound, kind of like when you have two metal parts connected by a bolt tightly but they still slide around. whenever i push on the brake in d4 all the way down to a complete stop, then let go of the brakes, it will move forward and then JOLT me forward after a half a second or so and this is when i dont press on gas it is just idling. can someone tell me what is wrong with this? do i have to get yet another tranny? GAH
    I honestly don't know about auto trannys. I've never owned one. But if you have the same problem with multiple trannys it might possibly be the TCU(transmission control unit) Just a thought
    Post count is not = to experience rating
    F22B DOHC
      Dude just do a 5-speed swap and be done with it.
