i got some kyb and generic adjustable springs and the spring dont come with instructions so any one know of a tread or a pictur of how to put them on cuz i put them on but dont know if i did it right
question bout lowering my car
PIctures of what you bought would help people.
i just need to know hat this bag full of rubber things are for an wher do they go there is a big one that i think that go in the rear but not sur also have little ones ..... rubber washers then dose the adjustable base go on th top and how far should it go and should there be any rubber bushing in between the spring and the adjuster LET ME KNOW PLEASE I NEED HELP
They are rubber rings correct? They are different sizes for different girths of shock. Find the rings that fit your shock and position 2 on each shock to the point that when you place the sleeve (the thing with the adjuster rings on it) over the shock there is a rubber ring at the inner bottom of the sleeve and also one at the top of the inner part of the sleeve. Make sure the sleeve is all the way down to the shock cup. I think that answers your question and I would think the rest is straight forward."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
FS Part out threadkoni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
Not sure what big rubber bushing you are talking about. I just know you need to find the correct size rings that allow the sleeve to fit over the shock and it fit snug where the sleeve isn't moving anywhere once it is on the shock. You do this for all 4 shocks. You are welcome to put more than just 2 rings on each if you feel the rings are small and will break or wear out quickly over time."This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
