f22b swap
    f22b swap
    i have a f22a1 and will be putting in a f22b.
    can i just swap the engines or do i need other things like a f22b ecu?
    yea you need the ECU
    Originally posted by kc8enb07
    does it come w/ jdm trash? they better throw away gold in it
      k i can just pull the preludes ecu out and just swap it out? what kind of tunin will i have to do?
        Its direct drop in pretty straightforward. You can use F trans and you just need the ECU. Its plug and play.
          First off, what kind of f22b is this?
          f22b1, f22b2, or f22b dohc?
          f22b dohc is the easiest swap out of the three.
          You can use your stock ecu, but it will run like crap. You can run a p14 from an h23, but you will need to wire a knock sensor in your block, you can run a p39, which is the engines ecu, or you can run a chipped p06 with an appropriate basemap.
          do some searching, everything you need to know has been covered by me.
            do yourself a favor and get the JDM F22B DOHC version. the SOHC Vtec sucks like Deever likes to say.
              Werd.
                no u dont need the ECU of a PRELUDE
                u can use the f22a... ecu it will WORK!
                  The PT6 will run the F22B DOHC BUT it will run like crap.
                    Well, do you have access to an F22B DOHC equipped Prelude? If so, then you must be from somewhere other than the US (Australia or New Zealand perhaps?)
                    The proper ECU for the motor is ALWAYS the best thing to use.
                    Any other ECU will not have the proper fuel map. It will make you run rich or lean in certain spots, which can cause trouble. It will run, but don't rely on a stock ECU that wasn't made for the engine for long-term use. A chipped and tuned ECU is another story... but you need it to be properly tuned to work properly.
                      so the rite ECU to use for the f22b is wat the p13? and the p14 is the h22 am i rite?
                        you got it backwards.
                        the right ecu for an f22b dohc is the p39. p14 is h23.
                          idk about u guys but i think VTECH sounds weird so thats a deff no go on that lol. i was planning on the f22b DOHC
                          i can find the engines online like ebay and other places like that. i just needed to kno if i needed to look for the ECU with it. does n e one not junk yard things n e more?! u can find alotta stuff there.
                              whats so confuzing about that
