Need some help on swapping a JDM H22 94/96 accord into 90/93 Accord CB3
    Hi..
    This is my first post in here...its early in morning here so i will make it short for now..
    Need some info regarding swaping h22 into a f20a,
    theres a lot of info regarding h22 into f22a at cb7 tuner..n i know the us models have o2 sensor n egr system..
    Currently my f20a with no o2 sensor n egr system..also known as CB3 in Malaysia
    My question is..can i bypass those 2 item on the h22 while doing the swap..coz i will be doing the swap me self..
    http://www.cb7tuner.com/vbb/showthread.php?t=5423
    Your F20A Carbureted? No you need the o2 for the h22a.
      Thanks bro for that link...I had that copied in my pc recently.
      So i have 2 use the O2 sensor For the H22a.
      What about the EGR system.?
      Details regarding my current F20a5.
      PGM-FI/manual trans
      Bypass throttle body coolant hose
      Bypass EACV coolant hose
      4-2-1 header warp.,custom stainless steel piping
      Medium light n balance stock flyweel
      Custom made coil overs..tuned for performance on track
      NGK iridium sparks plugs with advanced timing.
      Drop in K&N filter.
      Next project
      An accord or prelude H22a/manual trans swap
      Rear sway bay
      Grinded n balance camshaft, port & polish head, added washer for the valve springs and some adj cam pulleys.
      NGK blue plug wires
      Exedy Clucth,stage 2
      K&N cold air intake system
      Avfc Neo install n tuned.
        If you use a chipped ECU that doesn't look for the EGR, ie. P06, you wouldn't have to use the EGR.
        I don't use the EGR on my swap.
        As for the O2 sensor, you will need to use it.
          Sorry for the late reply..thanks bro for info.
            salam razif......
            come join us at myHavoc. i just swap BB1 engine.and few member just swap CD6.
            i`m from JB.u???
            just swap all wiring from prelude into your CB3.....its same bro!!
            x payah fikir nak disable EGR ..
            Signature Picture removed due to excessive size
            VOLVO 240GL bandit crew....all mighty supertank
              Hi..sorry for the late reply.
              I'am from Rawang bro..
              I was thinking of going for a BB1 H22a rather than SV4 accords H22a..so just swap the wirring from the prelude..ok..just wanted to know if i could just bypass the egr n o2 sensor...anyway i will just use them to make the swap easy n lucky i have a workshop to do the swap.
              There was recently a guy here did the swap with the prelude dashboard in the accord..took him almost 2 months to do it..
              If iam not mistaken u r the one with the wanted car pic..iam been following CB7 forums for the past 3 years n recently decided to register as a member..
              Its so cool to know that ur 4th gen accords are the most popular out there, with so many members n forums around.
