2.3L stroker h22a4
    2.3L stroker h22a4
    so im building a stroker in my h22a4
    i know they havea stock comp. ratio of 10:1 what would this bump the comp to?
    http://www.cb7tuner.com/vbb/showthread.php?t=37834
    go calculate it.
      Cisco Engine Calculator for the emeneffin win!
      I'll have to mess with that tomorrow to learn about his myself. I want to do the same thing to my H22 when I finally get around to cracking it open!
        Are you sure you are going to fix the h22? Or has the supercharged ponticrap changed you?
          brian crower racing makes a 2.49L STROKER KIT and its not that expensive...http://briancrower.com/makes/honda/h22h22a.shtml
          Bought from: 92acclude, almostJDM, cali-racer, MikeW, rexload, slick, sackingz123, so-calsfinest, lindiz, yeamans17
          Sold to: timmy0tool, sackingz123, judonoh, jdmhondaman, jdmaccord91,Ofr
          mycb7.com
          Members Ride
            Not that expensive? It's more than the H22 motor, trans, and ecu... installed!
            The F22 crank works. 2point6 was using a modified F22 crank with much success. He also once told me that 2.44L was about the safe limit of the H22. BC's stuff may be good, and perfectly reliable, but I'd rather save money and go the cheaper route... as long as I know it'll work!
              i ment in terms of stroker kits i was just looking at the price sheet
              mycb7.com
              Members Ride
                Ok, yeah... in terms of stroker kits, it's definitely cheaper than the $6000 2JZ-GTE stroker kits out there! But yeah, it's quite expensive. The ONLY really good part of it is that all the parts are matched, and are designed to work together. Of course, I'm sure those pistons aren't FRM compatible, so add another $1000 to that cost to get the block resleeved. Even with a stock bore, you couldn't use those.
                  if your buying a stroker kit you must be pretty serious-might as well just get a dart block if your throwin that kinda money around
                  mycb7.com
                  Members Ride
                    hahah thats way out of my price range plus I got f22a rods anda crank laying around
                    does anyone know a better way to get these effin piston pins out rather then fucking up the pistons banging on it
                      Hydraulic press.
                        well I know that lol
                        where would have one?
                          A shop.
