I want to go further
    I have finally have my Basic Bolt-ons and I would now like to start going further.
    I have heard cam gears are a good way to go but it seems to be that's starting to get to advance for me? I think pulley is what might be next. What is the next best place to head towards after I/H/E and weight reduction?
    Eventually, I'll build a block and all that.
    I should be getting an optima battery soon(battery of choice, correct?). I want to get in and clean a little bit. I'm having trouble getting the bolts off my EGR and ICV and etc.
    After that cleaning though, what should I staart? I'm always reading, this is my 3 hour on this site, I've been trying to understand ECU's and tuning right now and I just read a thread on a build. It's so confusing. In other words, I can take my car now that it has I/H/E and get it tuned but when you buy a chipped P06 or good ECU it's easier and a better ECU? or you HAVe to chip your stock ecu first in order to tune. Any good reputable tuner shops in orlando?
    No longer have a cb7.
    V6 POOOWAAAA
    lol, a buick.
    I'd go with a cam from an A6, H22/23 plenum with A6 runners, PT6 ECU, H22/23 throttle body and see how you like it. You WILL notice a big difference.
    Black Housing DIY 1991 Wagon Morimoto Retrofit
    JDM One-Piece Headlight Lens Repair
      Throttle body. How hard of a job is that?
      What about an intake manifold?
      V6 POOOWAAAA
      lol, a buick.
        That is basically what I described above. All bolt ons and OEM Honda!!! Search the DIY forums and you shall find the above mods.
          Really not hard its removing/puttin on would be hardest I guess? Its pretty straightforward. Obviously the tb is a lot less work than the IM. IM just has more bolts.
            about how much? I might notice it but is it there, I'm looking to add actual horsepower.
            V6 POOOWAAAA
            lol, a buick.
              h23 intake manifold
              272 cam
              contact wikked he lives in o-town he can tune
              im starting to learn how to tune as well
              75 shot of nitrous
              should put you well into the 14's
                Where can I pick up H22/23 stuff? and what's a plenum?
                V6 POOOWAAAA
                lol, a buick.
                  tb is easy man 20 min job at most
                  i can take mine off and put it back on in like 10 mins
                  I also have a f22a6 cam ill sell or trade ya if you want it
                    V6 POOOWAAAA
                    lol, a buick.
                      well if you do the a6 lower intake manifold h23a upper and a6 cam probably 10hp
                      its worth it
                      if you pick up a spare cam and send it to delta to get reground ($90) thats another 10hp or so roughly
                      I got a spare cam if you want it that way your car wouldnt be camless the whole time its getting reground
                        So when people say Delta 272 regrind that's taking your regular cams and getting a regrind? what's a regrind? and can't you just buy a cam gear off delta already done?
                        V6 POOOWAAAA
                        lol, a buick.
                          its not a ca gear its the cam itself no you cant delta does a regrind service meaning you send them a cam they add metal onto it and grind it to have bigger lobes making more power
                          you send them a cam and 90 dollars (I think thats what it is) they regrind it send it back then you install it
                            where do you guys usually get the cams and h22 intake plenum? junkyards? and also is it a straight bolt-on?
                            THIS CAR DOES NOT BELONG TO ME SO STOP GIVING ME COMPLIMENTS!! although it is quite nice....
                            Vehicular Lunacy At Its Finest
                              first off h22 shit doesnt fit anything but h22 shit.
                              second a plenum is the same thing as an intake mani, ive heard it referred to as the lower part of the intake manifold, and intake mani comes in two parts.
                              top and bottom, the top on the f22a6 has dual runners i believe, the h23 intake mani is a great mod.
                              you can get them from ebay, users here or junkyards.
                              cams from a single cam only fit a single cam. h23 f22a and h22 are totally different cam setups
                              getting an extra f22 cam is a good idea, the 272 cam regrind is a great all motor mod.
                              i/h/e, tune, port and polish an h23 intake mani, 272 regrind, and a 75 shot of nitrous is going to be waayyy faster than a stock h22 accord.
