When i drive for a while the oil light stays solid at idle and blinks when the car is moving. I dont have a leak anywhere? What else could be the problem? I get enough power and everything else but the light will not stop blinking. I drove the car about 200 miles on a trip last weekend and the light never came on but on short stop and go trips it does. I checked the oil and the level is perfect. Please help this is driving me crazy.
Oil light? Cant figure it out
I have the excact same problem as you. The answer would be either the malfunctioning oil pressure sensor or the oil pump. But most commonly is the oil pressure sensor. Cheap fix
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
Originally posted by DreCB7When i drive for a while the oil light stays solid at idle and blinks when the car is moving. I dont have a leak anywhere? What else could be the problem? I get enough power and everything else but the light will not stop blinking. I drove the car about 200 miles on a trip last weekend and the light never came on but on short stop and go trips it does. I checked the oil and the level is perfect. Please help this is driving me crazy.
Originally posted by f22cb7lxI have the excact same problem as you. The answer would be either the malfunctioning oil pressure sensor or the oil pump. But most commonly is the oil pressure sensor. Cheap fix
It's right above the oil filter.
If it's just a fualty sensor, it won't cause much damage, if any at all.
If it truly is your oil pump, your engine could be screwed.
An easy way to test if your oil pressure is good is to get a oil pressure gauge and hook it up.
If level is fine usually its the oil sending unit. Worst case scenario is oil pump but you will know if thats goin out.
