Secondaries wiring?
    Secondaries wiring?
    I have recently swapped in an a6 from an auto cb7, and my car used to be an a1 5spd i was wondering where to wire the "pink" wire from the iab secondaries if I reused the a1 engine wire harness and the a6 ecu, also I have a black/red wire in pin a17 plus it doesnt seem to open them when connected is there another place for that signal to come from? I remember when hooking up my wideband I had different wire harness than some other members that used the same wideband?!! Oh and my car is still a 5spd lol!
    WaC!
    are you sure its pin A17? are you reading the pinouts properly??
    1 3 5 7
    2 4 6 8
    thats how the pins read when looking at the ecu. the pink wire goes to A17 and the black/yellow wire can be spliced to a yellow *switched ignition* wire.
    F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
    Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
    Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
      the ecu's A harness goes 1 2 3 4 5 6 7 8 9 10 11 12 13 on the top then on the second row its
      14 15 16 17 18 19 20 21 22 23 24 25 26
      Right? so if it is on the second row and 4th from the end i am right!
      I need feed back please!
      WaC!
        Wrong, read the previous post. Odd numbers are on top, even on bottom. Pink to A17 other wire to switched 12V ignition.
        ...adjust accordingly
          hmm, i got cha now, but if you open the ecu it has numbers beside
          the #1 pin and at the other end of the top it has a #13 and on the bottom 14 and 26! printed on the circuit board in white! that would explain why theres two ways to look at the pinning!
          WaC!
