Is a 14b turbo good or aight for a H23 also how many Psi boost can run on a Stock h23?
H23 on 14b?
Find something bigger.
I'm bored and just feel like helping you out. The reason everyone is saying the 14b is too small. its not a bad turbo but when you get into the greater psi it makes hotter air which in turn shoots that air into your motor. if you get something bigger say a small 16g or larger it will have turbo lag but it will have cooler air. It is also hard for the 14b to stay out of boost because of it's size rather than a larger turbo. So if you're on the highway cruising you'll still be in boost. You can put the 14b on there but just take those things into considerations. Hope this helps and remember to use the search function its very very usefulDont drive faster than your gaurdian angel can fly
brakes
what part from a 92 prelude si do i need to change on my accord so that i could have the prelude front break set up. i heard it could be done but i have no idea of exactly what i need from a lude so that it is easier to change the rotors!! please email me for answer at eulogy_1981@msn.com
thanx 4 helpMy 92 accord
Originally posted by eulogy_1981what part from a 92 prelude si do i need to change on my accord so that i could have the prelude front break set up. i heard it could be done but i have no idea of exactly what i need from a lude so that it is easier to change the rotors!! please email me for answer at eulogy_1981@msn.com
thanx 4 help
http://www.cb7tuner.com/vbb/showthre...&highlight=roh
thanx 4 help
Originally posted by Bongowtf? what does that have to do with this post....at all?
