Whenever I turn on or off my radio the antenna makes a grinding noise from rising up and lowering. Anyway to get this fix? Or to I simply have to get a new antenna? TIA!!
Antenna Noise
If WD-40 doesnt help, you more than likely need to replace the motor/mechanism. Some ppl shave it and put it elsewhere, or in my case, i just pulled the old one off and replaced it with one of those lil black rubber "stubby's"
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
sounds like the motor is bad.F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
its the motor definitely. power antennas always eff up like that. what I did was pull the plug that gave the antenna power to go up and down, so now its up all the time. Its like a white plug which you can't just pull out. Theres a clip on a plug where you gotta lift in order to get it to disconnect. The entire assembly is under the antenna, obviously.
My gone too,i already looked for mast,motor rusted.Do u need to reloc some ground if i disconnect motor plug?Cause i have some bad interférences.
But,for my,bad sound mostly come out from rear speaker.The little material who stick metal and cartoon scoope was dryed and dusted out,so speaker was floated.I used this white little protector u find when u buy play-station2 or electronic.That a lot better,u just need soft glue and exacto.
Hi all
