Another Oil Leak Thread
    okay, so i just called the shop and got a price quote on getting everything fix. apparently, when replacing the o-ring... i need to replace the distributor cap/ rotor which would cost me around $120 including labor. sounds about right? i figured i needed to replace the distributor cap/rotor cause that thing looks bad now.
      okay, so i just finished replacing my o-ring only. talk about a quick fix. just take off your spark plug wires, remove the bolts to your distributor, pry off the o-ring. replace it with a new one and add black sealant adhesive around the ring, put the distributor cap back in making sure everything is aligned, put the bolts back in, plug your spark plug wires... and if you had a leak like me.... spray the spots that were leaked on with brake cleaner then you're good to go. seriously, within 30 mins it was all done. so hopefully, that's the only problem to my oil leak issue and don't have to replace my whole distributor. thanks everyone who helped with the inputs!
        Now bring you butt to the meet.
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          Originally posted by f22cb7lx
          A haynes manual will be a good source to follow.
          nothing beside experiance can beat a good haynes manual
          Current Cars
          95 Civic Coupe - ass tons of mods but always broke.
          90 Accord EX auto - no mods.
          90 Accord EX 5 Speed - no mods
          76 Datsun 280z - soon to be rb goodness.
          90 Lexus LS400 - low and slow.
          85 Cressida - soon to be four doors of 2jz love.
            if there's any local meets in the east bay then i'm good to go. just fully detailed my car in and out... show room status if you know what i mean.
              oil leak (different spot)
              i have a question but it similar to an oil leak, just not in the same spot. okay whats been going on with my engine is that next to the headers or behind them (closest to the P.F.I. or firewall) theres what looks like a manifold. anyways i pressure washed my engine about 2 weeks ago and the white smoke stopped from where i guess oil was at and then it happend again yesterday. then i looked and theres a bit of a pool of oil sitting behind my engine. does anyone have any heads up as far as what to do to save from expensive automechanical prices or time?
