Oil leaks
    Oil leaks
    I ran my car for about 20 minutes today on the driveway and i started to notice smoke coming from under the hood. I opened it up and it was oil that was coming from the gasket behind the exhaust header.
    My dad said there shouldnt be oil coming through there in any situation and i want to know if somthing could be seriously wrong or if i just need to replace that gasket.
    Is it coming from the valve cover gasket? or ont he exhaust manifold gasket itself? Im kinda confused.. You could just replace those gaskets.. Easy fix
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      its from the exhaust manifold itself. its leaking from behind the gasket.
      other then replacing that gasket is there any problem with oil comming from there? like do i have some serious issue?
        most likely oil from the valve cover is leaking onto the exhaust manifold, but could you a picture of it?
        Members Ride
          This isnt my engine cause its dark and my cameras flash is terrible.
          It definitly is not from the valve cover.
          It is coming from behind the gasket on the exhaust manifold at the furthest to the right cylinder.
