can a bad egr valve cause bad idle even though its blocked off?? thanx in advance
idle
You ever check your IAC and stuff first.
yes
i did cleaned it 3 times,replaced fitv,and speed idle valve,,plugs ,wires,dizzy,cap,rotor,fuel filter,checked for vac leaks,replaced im gasket vac lines,checked timing,checked injectors,only thing i can think of is coil or main relay and yes i've used the search for a long time now anywayz thanx 4 the help
Have you ever put a new IACV on or just clean. Sometimes cleaning it doesnt help and you just need to get a new one.
The main relay wouldn't cause a bad idle.
I'd start unplugging things to see if it gets better or worse. Ya know, like start it with the TPS unplugged, start it with the EACV unplugged, undo some of the non-essential vacuum lines.
Many things can cause a bad idle, so many things have to be checked and tweaked.
