Hey people, newbie with a problem.
Last night i just finnished installing my new to me F22a in my 92 wagon w/5-speed. I bought it as a used long block out of a prelude(yr?). My motor had a bad rod knock(ran w/o oil). So besides the knock the car ran fine before the install.
Chain of events; I worked late last night to put everything back together. Checked the fluids, pulled the coil wire the build oil presser, reinstalled coil wire and the car started fine. Car ran at high idle for 20 sec then droped to about 1k like normal warm up. After about 2-3 minthe car surged and died. Checked every thing( fluids, connecters and plugs, looked for any leaks) all ok so I restarted. Started fine ran good then surged and died . Installed the hood, started the car and started to pull the car out to take for a test drive, car started to surge but was able to keep it running with the gas pedal. As the car surged I could here a clicking noise under the dash and every time it clicked the lights would flicker. Finally the car died and wouldn't restart. Waited a few min the tried to restart. Car started then died right away. Also when car was surging and clicking, when it died the tach droped to zero as the the motor was still turning.
What I done since; Checked the forums, found the MFR and resolder the connections, no start. Pulled the banjo nut from the fuel rail and cranked over the motor, No fuel coming from the line. Checked for spark with a sparkplug on the VC, no spark. Checked all fuses, all ok. Pulled the three plug from the fuel pump and checked with a volt meter, found 12v between outer two and about 4-5v on the center with no change when cranking over.
I don't know if the MFR controls spark going to the dizzy or if I am getting proper voltage to my fuel pump . Any help will be most welcome.
