Bouncy coil-overs!!!!!!!!!!!!!!!!!
    whould the springs be my problem or the struts?
    my set up is:#1-coilover set up with kyb gr2
    last time I checked "#1-coilover set up" was an Ebay brand....not good...i am going to bet on a bad coilover setup.
    KYB GR2's aren't great, but they are wayy better than any generic Ebay brand.
    try to stick with competent companies: Eibach, Tein, Neuspeed, Sprint, and u can't go wrong
    DEVOTE
    FS: Lokuputha's Stuff
      #1 is Nopi, I believe. Either way, cheap shit.
      GR2s are also not made to handle a drop. I've seen them last a long time on a 3" drop before, but they aren't made for it. If you drive hard, you may have blown one or more already.
      But yes, cheap springs/coilovers WILL make for a lousy ride.
        sounds like cheap coilovers
        "This truck is 100% sh*ts and giggles."
        "Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
        You're not JDM until you have a car built in ohio with tons of bolt ons from ebay.
        Disregard females, acquire currency
        BUS 62 AIN'T F'ING AROUND!
          gr2 dont hadle drop too well, could be that but coilovers have always been bouncy to me..... i had a set of sprint springs on my gsx and when i put it in with gr2s, they were not a good match so i put stock struts back in with springs....
          part 1 part 2
            Stock struts would be worse.
              GR2's are like stock shocks.. They dont handle drops that well, and those eBay coilovers are garbage!!!!
                GR-2's are OEM replacements as said. They're designed for stock height replacement struts.
                Any sleeve style coilover will have a huge spring rate, which will result in excessive bouncyness.
                  Since GR-2 is a replacement it might not be dampening it properly. Usually the shock is there to absorb some of the bounce to improve ride quality a bit. So it can go either way.
                    x97825392398 really couldnt put it any better.
