f22b1 swap problems
    f22b1 swap problems
    i know, ive done searches on this problem and they all go no where, i need help. ive dropped the b1 in it turns over, i have spark, my comprision is good. and fuel is good. but it wont start. i have used the a6 wire harness with the a6 ecu. i know i have to swap a few pins and wire the vtec, this i know. the swap is very temp. just until i get the a6 rebulit the way i want it. can any one help. thanks
    pss. i know i should have waited and got the h22
    Does it backfire? Timing on point?
      yea it backfired, after it would turn over a few times, i thought i had i dizzy 180 out so i adjusted it, it got worse, then i put it back the way it was. now it just turns over, bbut wont start
        is your firing order correct?
        did you touch anything near the timing belt?
        f22 distributors can't be 180*.
        what year a6 was it?
          ^^ I would check firing order first then I would go to timing after that if its still not starting.
