noSPARK!
    noSPARK!
    Aight so I bought a car w/a f226 in it and that motor blew or something like that anyways I swapped another one in2 it and now that motor won't spark...I have never owned an accord til now and the only thing that i noticed from my civic's is that there is no ground wire
    all input will be greatly appriciated
    Satrt with tracing it back. Id start with the coil/ignitor. You can bring that to the parts store and they should be able to test it to see if its good. IF you know they are good then backprobe the problem more. See if all connections are connected. If everything is set right.
      well the thing that stumps me it that I just bought a new starter, distrubutor, cap, rotor, wires, battery, and iginitor coil but there is no spark...it trys to crank over but there is no spark...like I said on civics there is usually a ground wire running from the valve cover to the radiator support but on this cb i don't see a ground
        Give your thermostat ground a check. See if your getting any power from the coil plug. Could be a fuse but you never know. I need to see a wiring diagram I think there is a fuse before the coil.
          yeah...check your ignition fuse...
          A wise man sees failure as progress...
