engine shakes real bad when in gear i lifht up and took my front tires to see if i could see the problem and when i moved my brake rotors it movrd my engine dont know what it could be i check my motormounts and they are good any other suggestion
my cb7 engine shakes when in gear
Originally posted by canoengine shakes real bad when in gear i lifht up and took my front tires to see if i could see the problem and when i moved my brake rotors it movrd my engine dont know what it could be i check my motormounts and they are good any other suggestion
Hey man your going to have to be more specific then that....
When you moved your rotors your engine moved?
Is this a rough idle?
When is the last time you did a tune up?
Originally posted by mchaleysometimes my car idles low and the engine kinda shakes the car. thats at about 500rpm... if you're around 1000 then it should be about fine.
Something is binding up. Look around the axle make sure its pushed all the way in same as the intermediate shaft. If thats fine it could be however you install the clutch did a crappy job and something came loose.
why would it have to do with the cluth it shifh fine and runs it just shakes it may have to do with axles i took the front tires off and turn my rotors by hand while the car is in gaer and i could see the engine move every half of turn could it be a bent axle when i pushed the car to get my engine installed it dint have my right axle on but the driver was installed i felt the shake on the car maybe it has to do with that axle driver side dont know what to do any suggestion
Ok so when you drive the car does it feel like the car is going to shake in half? Also when you say you turned your rotor's and saw the engine move were you using your hand to move the rotors? I doubt it's a bent axle if you can drive the car without it wanting to jump off the road, also if you see the engine move while you're turning the rotors by hand I'm going to bet you that you need new motor mounts.
Runt
Originally posted by runtOk so when you drive the car does it feel like the car is going to shake in half? Also when you say you turned your rotor's and saw the engine move were you using your hand to move the rotors? I doubt it's a bent axle if you can drive the car without it wanting to jump off the road, also if you see the engine move while you're turning the rotors by hand I'm going to bet you that you need new motor mounts.
Runt
