Ultimate H22 Swap Guide???
    Has anyone ever bought this, and has it helped? also i am considering swapping in a JDM H22. i have read up on this, but i still have some questions. #1 i want the use the JDM H22 with my F22 manual tranny, all the mounts are going to be the same, right? since the only mounts that didnt line up was the h22 tranny. #2 axles, you are supposed to use the 2 axles and create one, what about the drivers axle? #3 if the JDM H22 is obd1 fomra 92-96 lude, what ecu will i have to get and will there be a lot of rewiring required? i have a lot more questions but i wanna get these out of the way first. I know these topics have been covered before, but im a noob and allowed to ask these "stupid" questions. Thanks in advance
    ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
    NE GUYS, Buy the last of my accord parts
    good luck with the swap 'cause i'm somewhat interested in doing the same thing too!
      Its pointless to waste the money when all the info is on this site stickied in the swaps section.
        how much do these guides cost?
          i have a copy give me your aim and i will try to send you a copy
          Click Me
            http://www.megaupload.com/?d=NO8OJ32O
            Click Me
              well first off i think you should post a link so we all know what you are talking about. secondly not that much rewiring if you just buy the wires from the ebay seller who sells vtec wires... basically if you dont want to cut off your harness that you get or bought ... from the swap, then you buy these and they are the same plugs for vtec and loomed ( still waiting for mine to come but thats what he says ) for like 32 bucks... i just spent 40 mins lengthening my 02 sensor to the header ( um.. took me like 30 mins to solder and cut off wires, measure etc.. had to do a good job ) and like 12 mins to protect the wires in the end with more electrical tape and loom...
                Search ebay you will know what hes talking about.
                  oh but i do. and i went through it... well it's vacuum hosing is a little different than mine.. it doesnt go over what to do with iab i dont think... and it tells you to lengthen a lot of wires. the only wire i have had to lenghthen is my o2 sensor wire.. the other ones i cut the loom from stock and was able to move it enough to get to the position needed, IE the oil pressure switch ( not the vtec pressure switch ) i moved it a couple inches to the right ( toward the distributor, and below the intake mani) and it was just enough to plug it into my old oil pressure switch.. it also doesnt tell you to re use your old oil pressure switch. or reusing your old egr valve or re using your old fuel rail. it says "custom fuel rail" which you could just use your old fuel rail from the f22...
                    I have it and its not really in depth. It's only a basic walkthrough. You'll find more info on this website let alone the net.
                    ...adjust accordingly
                      how interesting... thanks for the guide book
                        FYI theres a person on here that makes a custom trans. mount so that you can hook up the h22 trans. easily. It works great as im currently using one.
                          thanks for the link to the guide. it doesnt really seem to be in that good of detail. i dont think i wouldve been worth the $50. the engine removal posted here was a lot better than in there.
                            Originally posted by NorcoAccord
                            thanxz bro you the man!
                            this cost like $30. i allways want to see it what it looked like.
                            FS: DSM turbo parts,OEM parts, and more.....
                            My Members Ride Thread - R.i.P
                              yes i have it and unless you are doing the swap yourself no! not really helpful.......because most people doing swaps know EVERYTHING already so not very helpful to them as well
                              ......you can use you f tranny but gears are ratio'd differently(taller)
                              and the way way your f tranny lines up to your h motor will leave with one bolt left out but wont hurt anything
