Restore Oil Addative!!!!!!!
    Do any ppl here use it? I have been using it in my car(s) for a while but i was looking at the bobstheoilguy.com website and i checked out the lucas oil stab. and was wondering if the RESTORE did the same thing?
    sucks
    restore in a sense puts a thin paste like flim on every thing it might seem that its helping for now, but later down the line it just screws things up
    use lucas stab or Z-max is great think about it the FAA allows linkite which is what Z is made of and Shelby uses it too and the make up of linkite is tinier then any scratch or marks than your walls may have, it fills them up and helps but nothing beats just rehoning your block and new rings
    good luck
    i went over 88mph and its not even yesterday
    second try 112+ mph havent even gained 5mins
    stupid fluxcopasitor damned DMC parts
    my thread
    comin at ya
      Do you think it helps with the oil comsumtion and all that other mess that it says it does?
        Use normal oil. I dont see the point of additives in the oiling system. You maintain the seals and everything you should have no leaks and no problems other than the normal wear and tear through the motors.
          when i owned a vw, i tried different "oil" additives.
          with the honda, i plan on spending that 'extra' couple of dollars to buy good straight oil... (does that make sense) nothing works best other than plain straight oil (synthetic of plain), with a nicely tuned engine.
          additives just "mask" other problems you might be having in my honest opinion.
          Restoring a 1990 LX Coupe as my daily driver!
          Completely stock
          Yes, I race R/C Cars. (Team Stryker)
            Did use it once on a badly neglected Talon (NA), did help some in that situation.
            Other than that, I don't bother.
            Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
              Thanks for the help guys ill take yalls advice and stick with good motor oil.
