no spark, won't start :(
    Hello, I was driving my car the other day (92 lx) and I was just going to back into a parking spot and as I put it in reverse I thought I stalled. When I went to start the car again it wouldn't start.
    First I thought it was a dead battery as it didn't make any weird noises and it turned over just fine. I got a jump and nothing, so I had it towed to a mechanic and he said he figured it was the distributer. He swapped in a new one and nothing
    Edit: He said he just tried the distributor and coil.
    Is my ecu dead?
    Could this be my main-relay? Can someone direct me to where that is located?
    Any suggestions?
    Thanks,
    Dave
    Does anyone have any ideas why I'm not getting a spark??
    Any idea where I can start?
    Any help would be great.
    Dave
      did he replace the whole distributor or just the coil in it,
      it might be your igniter, and also check all your fuses, there is on the driverside kickpanel that i blew out and also had no spark, so try that
      Members Ride
        one of your fuses or ignition relay blew.
        miss my turbo cb7
          Okay, thanks fellas
          I believe he replaced the entire distributor.
          The car is on it's way to my place, so as soon as I get it I will check the fuses.
          I looked up "ignition relay" in my service manual and can't seem to find anything. Do you have any images of this? Or could you tell me what to look for?
          Dave
            Originally posted by kingdave9
            Okay, thanks fellas
            Dave
            it should be in your fuse box under the hood. if it doesnt click when you hit the run position on the key (not starting it) then the relay went. switch the relays and see if it starts.
            miss my turbo cb7
              10-4, I opened up the fuse box and your right the ECU fuse (red, 10A) is toast.
              (I'm wondering why this would happen, seems odd)
              Where might I purchase a replacement fuse, do I have to go to Honda?
              Thanks for leading me in the right direction, you've saved me a huge headache!
              Dave
                i do believe a 10amp blade fuse is a 10amp blade fuse.
                any will do from your local auto parts... no honda "fuse" needed ;-)
                Restoring a 1990 LX Coupe as my daily driver!
                Completely stock
                Yes, I race R/C Cars. (Team Stryker)
                  Great!!!
                  For the time being I took the fuse out of the running lights and it starts like a champ!
                  Thanks everyone for the help, I really appreciate it.
                  Dave
                    local parts store carry quite a bit of them.
                      quite amazing what a little 10amp fuse will do to these cars eh? =)
                      Completely stock
                        lol... that sums it up nicely
