heres a stupid question but here it goes when you were changing everything did you reconnect the ground on the block by the the powersteering pump there actually should be two one from the valve cover and one from the PS pump
also if the starter is going out it will drain tons of juice or its the ground under the main fuse box is bad
thats all i can come up with since you changed your alt and battery unless the new alt is defective it can happen
good luck
edit insert
the powersteering ground should be a 12ga wire the one that goes from the main mounting bolt from the PS pump to the same location the valve cover ground goes to
good luck
edit insert
