Bisi Ezerioha (Bisimoto) is making 400hp with his carbureted NA F22A on pump gas. It is a very capable motor, in the right hands.
Maxing out an F22a1
I just took some fine grit sandpaper to 93twodoorLX's manifold when we put it on...
A phenolic gasket would be a good idea as well. It helps prevent the manifold from soaking up heat from the head, keeping the intake charge cooler. www.bisimoto.com has them for a reasonable price.
If you get a professional polish job on it, it WOULD be better... but not really necessary. The gains to be had from the intake manifold aren't that significant to warrant the cost, unless you know where to have it done cheaply.
Yeah I think i know a dude who could PNP the IM for me at a decent price, would like it to be done right the first time, ya know. also will i still be able to use the same actual intake that i could with the a1 IM??? because i found a nice Injen one for pretty cheap.Last edited by JDM_honda_PIG; 05-13-2007, 11:05 PM.
Originally posted by deevergoteThe H23 throttle body is a bit larger, so the intake piping may need some modification to fit. An intake made for an H22 or H23 would probably give the best results. 3"
the dude i got it from pulled it from a 1993 ex doesn't that also have the a6 motor in it??? the F series engine list had the a6 listed as the motor for that car.
