Whats the deal with Cams?
    Ok
    So if stock cams are ment with fuel efficiency in mind, and aftermarkets have horse power in mind... what would an aftermarket do to fuel efficiency?
    aftermarket cams get power by opening the valves farther and maybe a touch longer for more ventilation... right?
    So if thats true, how would more air, etc hurt? Wouldnt it only help fuel efficiency?
    My Car
    FREE Web hosting solutions
    not really because the more air there is detected, the ecu will dump more fuel to balance it out, i forget what it's called but it's basically the same idea as "Yin and Yang." all about the balance.
    dang that sounds like some fortune cookie shit right there.
      Strange, so it would bring in more air and because of that more fuel... more fuel = more hp... less gas milage...
      So the valves being open more would bring in a tad more air, hrmmm
      why cant more HP bring more fuel economy also :P
      My Car
        they never said speed was cheap.
          Horsepower and fuel economy can go together. As long as your motor is tuned to run lean, however, like stated above, the more air you pack in, the more fuel is also needed. There is a fine line between HP and fuel economy, but that's why Honda pays it's engineers big money to make 120bhp per liter and still get 35mpg. It's all about efficiency. Although we all know that no one is getting 35mpg if they're mashing the gas from stoplight to stoplight.
          I don't know, I'm just in the game for the power, fuel economy will come with a good tune, but you'll never really get the best of both worlds unless you stick with OEM or very light well planned mods. Just my 2 cents.
          -Kyle
          SOHC Non-VTEC F-series for life
          "It is the fools prerogative to utter truths that no one else will speak."
          -Morpheus (The Sandman)
            Stoichiometry
            http://en.wikipedia.org/wiki/Stoichi...f_common_fuels
            DEVOTE
            FS: Lokuputha's Stuff
              Yeah but even with a high horsepower honda motor your still gonna get better gas mileage than most other cars on the road.
              Arcadia Green Crew Member #9
                Tuning will net you better gains than running stock ECU with modifications. 14.7 is stoichiometric as people call it. That is the ideal AF for cruising and idlilng because it gets the best "burn" Some people can go leaner depending on setups which helps them out. As long as you dont stomp on the throttle everywhere gas mileage should be fine.
                  Originally posted by lokuputha
                  Stoichiometry
                  i was thinking of that one Russian word for patriotism...
