90 accord idle problum
    OK,
    I have a 90 accord, it has problems idling in all the gears (auto) the Prev. owner recently put new sparks in it, ran fine for a week after buying, then started acting weird only in Park. Then the next day, it started doing it in Drive and reverse and neutral as well...Couple of things before you answer that you should know,
    First, his idle is normally set to 1400 cause it responds better,
    second, What it is doing is it will crank on, (both hot and cold startups) and will go from about 3K to about 1900, then shoot back up to about 2750 then back to 1900 and it does it over and over and over. Now, if you are at a light, if you hold the brakes and barely press the gas to where it sits as 2K its fine....problem is, thats not good for gas, and it is hard to brake now, because at any time if its below 2K rpms it will do the *** thing.
    I also don't think it is the ICV because if it was, it would have taken longer to start acting up. OOOO, sometimes, rarely, it will not be ***, and it is fine. normally it doesn't do this, but it will sometimes not do it for about 30 seconds.....then start again. Now the oil is about 1/3 a inch higher than the second dot for the oil level on the dip stick.....i Also sea foamed it yesterday with no luck of subduing or temperately fixing the problem.
    OK,
    Now for the specs of the car....
    1990 Honda accord
    1993 prelude H23 engine and tranny and stock 93 ECU (90K miles on both)
    Sfac2(think thats the right name) piggyback (dyno tuned by a local race shop)
    DC ceramic headers
    3" DP back exhaust
    PLEASE HELP!!!!! I really need the beast back up and running asap, and really need your help. Thanks....
    O
    PS the prev. owner also said he had the same problem, and he took it to a guy, and he screwed in a flat head screw on the throttle body, and it fixed it......we tried to unscrew it to see if it would change/fix it, couldn't even get it to come out(stripped)!!! i am a car guy (prev. member of Turbobricks) and i honestly cant figure out what is wrong with this car....please help!
    a Honda that eats mustang GT's for breakfast, wow
    Bouncing Rpms? One of your igniters has probably gone bad. Heres a picture of what the little guy should look like.
    And it should be on the distributor. Sorry to say, they are incredibly simplistic, but since you can't make them in your own back yard... you pay a pretty penny for this little piece of plastic and metal. I think its worth more then its weight in gold.
      check for vacuum leaks by spraying some gum cutter all around and listen for a change in idle.... the first thing i would do is let the car warm up, then unplug the iacv and set the idle with the throttle body adjusting screw until its around 800-900 rpm.... if you cant get it near there then theres a 99% chance you have a vacuum leak...
      this same thing happened to me, i thought it was the iacv but it ended up being an intake manifold leak on the #1 runner...
        clean out the throtle body,theres an Idle Air Valve the need to get clean right in front the intake manifold it has 3 bolts ...clen it with brake cleanneror carb cleaner and the start and checkthe rpms
        turn the key,Clutch-Gear-Gas ..Gone.... R.B.
          well the throttle body should have been cleaned when i sea foamed it, and the idle set screw....is it a flat head screw, cause if it is, its stripped
            WTF....fuel/oil doesn't go through the throttle body. Seafoam didn't touch the TB unless you dripped some on it from the container. Plus, you have WAY too much oil in the engine.
            Check out ESP engine mount kits for your CB7!!!
              Na, you can put sea foam in threw a vacuum line that plugs directly into the Throttle body. But i went to auto zone, he said that it couldn't be the Igniter because it doesn't sound like it would act the way it is acting....although you could be right, because i know the fuel delivery system isn't it, and i don't think its a vacuum leak (going to check that shortly) so if it is nether of those, it has to be something to do with the ignition.
                .....ok, not cool......i cleaned the T body and i cleaned the ICV, and it didnt fix it. Then i started spraying carb cleaner for vacuum leaks, becuase you can hear a really loud leaking sound near the injectors. A little cap thing on the valve cover was leaking after i turned the car off, so i tried removing the cap.....it just broke....but i have had no luck and i am starting to lose moral......please help me.
                  Ok, well it aint really fast bouncing, its a semi slow bounce...and agian i hear that noise that sounds like a BIG LEAK!!!
                    Bump!! PLEASE HELP!!!
                      Bump! one of the 3 nuts that hold the DC headers to the down pipe is missing, would that cause that weird idle?
