Changed my front rotors and calipers, so I went to bleed the brakes today. Used the vacuum pump one man method and that sucked, so I got a friend to come over and work the pedal for me. The driver's side bled fine, got a nice flow of break fluid with no air bubbles. Then moved on to the passenger side, and all I get is air. Not only that, but the fluid level in the reservoir doesn't change at all, not even the slightest bit. I siphoned the fluid out of the reservoir and took it off, but couldn't find anything blocking flow.
So...anyone have ideas for why the passenger side doesn't seem to be pulling/pushing brake fluid and why the level doesn't change in the MC reservoir?
As a side note, everything worked prior to all of my screwing around, stuff was just worn / old.
