Noob brake questions
    Am replacing the caliper on 93 LX. The Haynes manual says to insert a small piece of the "appropriate" size hose to in the banjo fitting at the end of the brake line (to stop the line from leaking fluid) . Anybody know what the right size actually is?
    Thanks
    Get a pair of vice grips and clamp. NOt recommended but it works. If not your just gonna be bleeding the brakes for a while.
      Just bleed it all out. Now would be a good time to replace your brake fluid.
        Yeah i would definitly just bleed the whole brake system.
        If you don't want to do that and you can't find the actual size I would just tightly pack a paper towel or something in the loop. That will slow the flow down enough so that you can change the caliper. I did my rear calipers on my Nissan this past winter and this is what I did. Just make sure you bleed them correctly after.
        "Auto racing, bull fighting and mountain climbing are the only real sports....all others are games."
        - Ernest Hemingway
          Get one of these:
          Just so when you push on the calipers the fluid doesn't rush back to the reservior. When done just pour it back.
