Check Engine = Good!?
    I have had my car for almost a year now and lately I have noticed that during long periods of travel my check engine light comes on and my car performs WAY better. I took it to the Honda Dealership for a diagnostic (Yeah they raped me.)to see what was going on. They of course gave me the run around. But Basically here's what's going on:
    No light - Slow/Sluggish acceleration, Almost like its having trouble shifting from 1st to 2nd gear (AT). Weird "overbuzz" noise. Sounds like the engine is working harder than what it should be under acceleration. Poor Throttle/Reaction ratio. I have to halfway floor it to go almost 50. Weird smell. Rough Idle. Weird sounds at idle. Sounds like the engine might cut out. Weird knocking sound upon acceleration.
    Light - Of course Its not sexy. Besides that nothing.
    I asked some of my friends what may be going on and they said that some kind of check failed in either my Engine or transmission and it reverted back to the default settings or something along those lines. Here is where this vast collection of knowledge comes into play. Is there anyway I can force my car to run in default mode or whatever at least until i can afford to fix the problem?
    Check the code behind the CEL by doing that jumper thing, then at least you could pinpoint it to what may be tripping it. To tired to find the thread on it should be a sticky in the main tech forum CEL diagnostic or somethin.
    ..It's not cheap to build a fast CB7, especially NA. However, if you're willing to put the money into the car, it's well worth it in the end. There ARE faster cars out there, but some people, like me, want THIS particular car to be fast!...
    Sold to:tanNn2koo,9tAkord,ThrakBarts,nahmo,andrizzle,or anger
    Bought from:93a-lude, bruno8747, soysauce
    1993 H22A cb7 <3 miss you
    04 WRX stg 2 sedan
    Current - 02 WRX stg 2 wagon
      Thanks man. GO TO SLEEP! lol.
        So you are saying your car performs as normal when your CEL(check engine light) comes on? Weird.
        When did you last get a complete tune-up done? Have you checked your ignition system as well as spark plugs? When was the ignition timing last checked and set to factory specs? Those are a few things you might want to consider.
        Also, the first thing I would do, is pull the codes as soon as you have the CEL come on.
        Members Ride Thread
          my car used to do the same thing. i threw egr and tps sensor codes and i fixed my throttle position with a multimeter and seems to be better now
