Car sounds wierd after headgasket install.
    My car needed a new headgasket (blown). First time i put everything back together, the car wouldnt turn over. I took everything apart and did some cleaning. Now i got the car to start, but it sounds strange, like a lawn mower. I also see coolant leaking between the head and the block. Could that be why the car sounds the way it does, or is it because my timing could be off. And no i did not install the headgasket up side down.
    Thanks
    My 90 Accord LX!!!
    Check it out!!!
    well coolant leaking from the block isnt good.
    are you sure your block is not cracked? thats what happend to me.
    sounds like timin is off tho but the leakin, not good
      No its leaking between the head and the block, not from the block.
      My 90 Accord LX!!!
      Check it out!!!
        Bump
        My 90 Accord LX!!!
        Check it out!!!
          timing is good? plug wires are in the right order? firing on all cylinders?
            Pull it apart and redo it.
            1. Thats not a good sign
            2. What did you clean?
              Thanks
              Resurface block and head? If its still leaking obviously its not sealing. Yeah, your car will soung like shit when the engine has no compression because the head gasket's leaking
                Yeah thats what i need to do. Im going to do that next week, and get a new timing belt.
                My 90 Accord LX!!!
                Check it out!!!
                  So could that be why my car sounds the way it does????
                  My 90 Accord LX!!!
                  Check it out!!!
                    Don't start it up again until you're sure that you have good mating surfaces between the head and the block and the headgasket is installed properly.If its leaking, then the seal isn't good. Redo it and test again. If its all good (sounds good and no leaks) then I would suggest a compression test on all four cylinders.
                    ...adjust accordingly
                      X2!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                        Ok Thanks
                        Going to get my head resurfaced tomorrow.
                        My 90 Accord LX!!!
                        Check it out!!!
                          headgasket
                          im willing to bet that you probably did not tourqe the head bolts properly or you have a warped head reason i say is cause it happened to me on a corolla i did ahead gasket on before taught me a lesson hope this helps
                            Ok Thanks
                            dont forget to check the block out too. And dont just do it with a ruler or something stupid.
                              make sure you tighten the head bolts in the correct order. later.
                              Avoiding dirt at all costs
