Throttle sticking?
    Throttle sticking?
    I'm trying to trouble shoot some issues with my Accord and this one is eating at me more then any other. When I step on the gas and then let if off my rpms continue to rise for a sec before backing off. I don't know what could be the cause of this, but I'm taking a stab in the dark thinking it's a vaccum leak of some sort. I've have had this problem since I replaced the intake manifold and I didn't replace the gasket, which I probably should have. You guys have any ideas that might help me figure this out. Thanks
    1. Check for leaks as you mentioned.
    2. Check throttle cable adjustment.
      When you let off the pedal does the pedal come back up with you or does it stay down for a second. If it stays down for a second check the whole length of the cable, the TB, and around the pedal on the inside to see if it's catching on something.
      R.I.P. CB7; hello spec-v!
      Member's Ride
      FS thread: full part-out
      Help me with my spec-V fund, buy my stuff!!!
      Degree of rice and performability are inversely related.
        You can adjust the throttle rotor, and if its sticking, you can loosen the nut holding it down. I had to do this when I was installing an h23 TB, it took several adjustments before I got it right.
          Try lubing the rotor, too. When I cleaned out my TB, I didn't lube the rotor when I was done, and it was sticking. I couple shots of lube on the throttle shaft was all it needed.
          Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
            I had alradey lubed the rotor on the TB and adjusted the throttle cable as well, so I'm assuming that all that's left is a vaccum leak? Unless there is something else I'm not thinking of. I guess I'll have to give it a once over to find out where I may have a leak.
              Test your TPS (Throttle Position Sensor).
              Check out ESP engine mount kits for your CB7!!!
                explain.
