Power steering fluid sqirts out!
    No leaks untill now, but everytime I park p/s fluid gushes out all over the road! Is the pump creating back pressure? I did not over fill and it has oem fluid in it. Has anyone else had this problem?
    search.
    wheres the fluid coming from?
      reply
      I did search. Its coming out of the reservoir.
        if its frothing out the reservoir, then somewhere in the system it means your pulling in air. This happened to me, and it ended up the p/s pump needed the seals replaced.
          Alright thanks. I will check.. otherwise I will just loop the lines and take the pump off.
            have you put only Honda fluid in the PS system.. or Honda approved? You have to use a certain fluid that is safe for Honda's or you will mess up the seals.
