CB7 Dirt track car Engine
    at the end of the straights i'm bouncing off the limiter at about 6100. In the curves i'm high 5's dropping till i get out maybe mid 5's on the way out of the turns by time i get to the next straight i'm bouncing off the limiter again rinse repeat 20 laps.
      If the motor pulls to 6800 i'm still not able to get over the 6100 rpm limit correct unless i get a ecu that has a higher cap?
        Correct.
        My 1990 EX ECU had no rev limit, at least not below 7,000.
        The PT6 (F22A6 ECU) originally had the rev limit at 6500. When I swapped the plenum, it went up to about 6800.
        So I don't know if they programmed it to work based off of MAP, or if it was a hard limit.
        It really surprised me that it moved though, and it stayed at the higher RPM, even in higher gears.
        If you are bouncing of 6100, then I would just stick with the Accord tranny.
        I am not sure how much more the H23 will raise your revs, and I don't know if your limit will move up like mine did. Maybe it was fluke or something.
        Besides, you might get to redline at that point, and be fine, because it won't pull too much passed that anyway.
        But yes, I would get the PT6, or a programable and tunable ECU because they have the best fueling for your setup. The PT6 will probably be fine.
          looking good!!! but if your going to rebuild i'd up the CR and put cams and vary mild port work
          2004 Audi A4 Quattro 6 speed
          2002 Chevy 2500HD LQ4
          1995 SE 240sx 5 speed Ka-T re under construction
          1991 240sx current paper weight for sale
          Have a 240sx Q ask me
          Sorry I just think body kits are ***.
          Still lurking around......
            Looks very nice and, umm, dirty . How did you manage to break the Honda emblem on the steering wheel in the third to last picture? You must run that car pretty hard! I'd like to give you some advice to help you beat those v-dubs, but I'm still trying to figure out how to work my car!
              So, umm, do anything new to the car? Hopin for an update!
                Originally posted by Leung
                i'd just do the P&P and not tell anyone. really now are they going to bust open your engine and look inside to see if you had that done?
                which engine do you have right now?
                you would be suprised how much that happens when theres big money involed... i got 3 dirttrack around me... guy i use to work for runs 3 classes late model superlate model and 4 banger. and he has had to break down his motor and prove what was in it before he got the win......
                Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
                But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
