I'm getting mixed reviews on this product. Are they worth using? Do they really decrease horsepower? I have a short ram w/a Tornado at the intake end, is this sh*t robbing power and adding just MPG? I hear theres an article but need to know if I should remove it. I bought it a year ago and still have it on but its for that 5hp its supposed to add.
Tornado Intake
dood...
you should do your homework before adding ANYTHING to your car. The Tornado is not designed to work with your Fuel Injected car. This item was originally designed to work on carburated or throttle body injected engines. The way it works is to get the air spinning in the intake tube and then catch the fuel in the carb and atomize it better and suck it into the engine. This will make for better combustion.
On a Fuel injected car, you don't really have the chance for the turbulant air made by the Tornado to make any real effect on the fuel coming out of the injectors. This is because the injectors are so close to the inake valves.
In my opinion, unless you go nuts and carburate that car....take the thing off and use it as a wrench holder on the side of your toolbox.
my buddies truck
my buddy has one on his 06 chevy colorado, most annoying thing ever. Sounds like a blow off valve in action but it is constant and without the effect of a turbo. 3 thumbs down from me, dont ask where I got the other thumb but my roomate my be in pain a while for buying this stuff.
Mine was $5.oo from a friend with a 5 fingered discount, and like I said it was a year ago when all write ups were "promo" good. Thanks for the info though. I'm taking it to heart and will pass it along my friend!
I think it's intended to be a joke...
The Tornado, or any similar thing, is useless. All it does is add restriction to an otherwise free-flowing intake. That means no greater MPG, no more horsepower.
Think about how your intake is setup... the air goes in the filter, up the pipe, through the throttle body, into the plenum, down the runners, picks up fuel from the injectors, and gets sucked into the engine through the intake valves.
Now, think about what the Tornado claims to do. It says it swirls the air to help with atomization and even distribution... makes sense, right? Until you factor the plenum into things. Once the air gets in there, all swirling stops. In fact, a certain level of turbulance is GOOD in the plenum... otherwise, there wouldn't be even distribution of air to all cylinders (cylinder 4 would get all the air if it went smoothly to the very back of the plenum and down the intake runner...)
I don't know much about carbureted cars, so I can't really back up the functionality there...
However, a properly designed and tuned carbueretor isn't a bad thing. Bisi runs 9s in his NA carb'd F22 powered Insight. He estimates that a CB7 with that engine could potentially run low 11s.
