h22 is running messed up
    hey guys i just baught an accord with an h22 with the f22b 5spd tranny
    and when i start it up it reving up and down up and down like at 2 rpm is their a way i can fix that even if i change the throddel setting when i turn my lights on it still dose it
    no one knows?
      there have been numerous topics about surging idles, have you tried doing a search? Try it and you might find your answer. Good luck!
      SOLD!!
      Boosted H22
      375whp 298 ft/lbs at 15psi
        Theres a problem with your idle, start from there, check the sticky's and search for threads about idle problems
          Take apart your throttle body, clean it, new gasket,, your set ......
          93 Accord H22.. 10th anniv.edition-wrecked R.i.P
          99 EM1 Boosted type R- Jacked and never found
            re
            well my oxygen sensour is gone could that be the problem ?
              you forgot to mention that part .......
                also check ur tps on the back of ur throttlebody
                Bought from: 92acclude, almostJDM, cali-racer, MikeW, rexload, slick, sackingz123, so-calsfinest, lindiz, yeamans17
                Sold to: timmy0tool, sackingz123, judonoh, jdmhondaman, jdmaccord91,Ofr
                mycb7.com
                Members Ride
                  yeah that could be it, or a vacuum leak
                  SOLD!!
                  Boosted H22
                    Idle adjustment screw on the throttle body. Turn it.
                    IACV. Clean it.
                    o2 sensor... YOU NEED THAT! Get OEM Honda... I've heard more than one report of aftermarket (Bosch, mainly) o2 sensors not working correctly.
                    Are you using the H22 ECU? (it should be marked P13)
                    Also, please don't simply tell the noobs to search. At least offer them a bit of information to go on. When you're completely new, you don't even know what to search for!
                      Well we did kind of tell him to search for idle problems..."idle" being the keyword of the search. I wouldnt just say "search" you obviously have to give them some kind of start
                      SOLD!!
                      Boosted H22
                        Yeah, that's why I didn't delete anything... But anyone who reads what you say may feel that it's acceptable to just say "search" in the future.
                        Plus, the search function REALLY sucks!
                          Sorry bout that deev, I didn't realize it was the beginner forums until you said that
                            You guys weren't totally wrong... it's better than "search, noob!"
                            But it's best to try to give at least a start of a solution, if you don't want to go through the whole thing.
                            Plus, when someone DOES search, they're going to find more threads like these, that say "search" than they will threads with actual answers!
                              X2, It usually takes at least 2-3 pages before you find what ur looking for, and usually they link you to other parts of the site...
                              Yeah, Preludes
                              Originally posted by deevergote.
                              Why can't people just search OT to see if someone else posted the same random thread?
