ball joint?
    replace the whole arm. by replacing just the joint, you weaken the metal. the lower joints can be replaced.
      thanks!!! thats all i need to know!!! thanks guys
        Originally posted by tig3rpaw
        i just call honda dealership. n the guy said i had to get the whole control arm, for the top? but, he said the lower ones, i didn't have too, i can just install the ball joints.
        He is correct. I purchased two front upper control arms and it was pretty easy to replace. The lower one was more difficult but can be done. If you are not comfortable doing work on your car I know someone who can do it and can do it for a whole lot less than the dealer. I might be able to help you if I have time especially since you seem to live close but am pretty busy as of lately.
        "This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
        FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
        http://www.cb7tuner.com/vbb/showthre...10#post2119010
          yo! let me know? how much? that sounds good?
