yo! guys i need some help? if yall can go check out youtube type in 90 accord. theres a video of a 90 accord runnin loose on a ball joint. n it sounds really bad. my is started to sound like that at 75 mph. what do yall think i should got for? a. new ball joints or b. camber kits also my bottom ball joints r bleedin too, should i got ahead n replace those too. the ride is drop also. do all think the problem will stop when i get it fix or it well b too late? let me know yall. thanks
ball joint?
If your ball joint boots are cracked, replace them ASAP. A failed ball joint will be catastrophic, and at 75mph, it would most likely kill you.
I had a wrecked DX in my driveway. I wanted to move it further into the driveway, so I had my wife steer while I pushed. The lower ball joints weren't on properly... the angle of the wheel was scary. I would NOT want to imagine that at speed!
Get joints from Honda. They cost more, but they will last. Cheap crap can fail, and the ball joints are quite possibly more important than your brakes!
BUY them at the Honda dealer... install them yourself or have them done elsewhere, as the dealer will be quite expensive. Ebay parts are not as good. I have ebay upper ball joints on my car now, and I'm not thrilled about it. I have yet to install the lowers, and I probably won't... Honda parts are the only ones I really trust.
Originally posted by deevergoteYou're lucky you didn't crash!
I believe that happened to Accord R33 as well... he had pictures of where his frame slid across the highway.
that happened because (we beleive) some ass loosened his lug nuts and they sheered off causing the tire to come flying off.
Either way not a good experience. I would most definitely go with the Honda products. i wouldn't go with anything like that from the junkyard. to me its just not worth the hassle.
As for the bottoms ones their not too difficult to replace. A little time consuming yes but it can be done by yourself."Auto racing, bull fighting and mountain climbing are the only real sports....all others are games."
- Ernest Hemingway
