Whats The Best Way To Bleed Ur Clutch Pumps
    I INSTALLED A NEW CLUTCH AND REMOVE BOTH PUMPS AND NOW I DONT HAVE ANY PREASURE MY CLUTCH PEDAL IS DOWN, ANY TIPS??????
    http://www.cb7tuner.com/vbb/showthre...ighlight=bleed
    That's the best how-to on bleeding I could find. Makes sense to me!
      reverse bleed it... get yourself a fluid transfer pump from your local autoparts store about $5 bucks and get yourself some dot 3, or superblue ate fluid like i have...
      loosen the bleeder screw on the slave cylinder stick the hose end of the fluid pump on it and start pumping... oh and be sure to take the cap off the master cylinder...
      put some rags around the master cylinder and OVER FILL IT.... this gets out a all the air... then just suck the excess out of the master cylinder... done and done
      I need NOS... give me one of these... make it 2... oh and hairy... i need it by tonight!
        thanks im goin to try this way everything is done troug the slave cylinder and it sounds easy
          it is... about 40 seconds of time... you will feel stupid if you tried to do it the other way because this way is soooo much easier
            pretty simple
            what he said. good luck
            chuck norris' mother once called him charles, only once.
              yea it work
              that was so easy now my car wont shift i have preasure on my pedal but no shifth when car is on
                i just gravity bleed mine open the valve on the slave cylinder lift ur clutch pedal and let it drip till it comes out even close the bleeder plug and u should have pressure. if u cant shift into geta after the bleeding u may have crossed ur linkage
                sold to the highest bidding stanger i miss this bitch
                the 93 ex to come soon
                  THATS THE PROLBLEM IM HAVING IT WONT SHIFT WHEN IS RUNNIG WHAT DO U MEAN BY CROSSING MY LINKAGE??????
