Suspension Help
    Suspension Help
    i'm just wondering if anyone know whats the lowest i could drop my car without having to change my shocks i don't wanna drop it too low...i just wanna drop it enough to lose the gap...my wheels are 205/40/17 its pretty much the same as the stock wheel but the stock is 195/60/15...and i just wanna know if i'm gonna need a camber kit?
    .75 H&R OE
      its not the height, its the spring rate. the stiffer the spring, the faster it's going to blow your shocks. the eibach pro kit and nuespeed soft sports are 2 options that probly dont need to be paired with an aftermarket shock. i think cpmike ran sportlines for a long time on stock shocks and was ok too.
        Most low drops under 2 inches have a low spring rate which you can use your stock shocks, they will still blow out sooner than stock though since they are working harder. I was riding on sprint race springs with stock shocks dropped 2.25 inches for 2 years and my shocks didnt blow. I think one might have blown a month before i totalled my car though because it was making a lot of noise.
        Coilover sleeves will blow your shocks almost instantaniously.
        camber isnt really an issue under 2 inches if you rotate your tires and have a good alignment. I had very small tire wear from camber so i never cared to get a camber kit.
        Possible owner of a CB7 in the near future
          ^^clean cd5
          am thinkin of coilover sleeves for my next cb7 but i want a smooth ride like my s-techs but a better drop.
          i might go neuspeed race or h&r race springs.
